Transient electric field under impulse voltage with nonlinear materials
Posted 13 nov. 2014, 18:25 UTC−5 Electromagnetics, Studies & Solvers 3 Replies
Hi all,
I am trying to model a nonlinear permittivity material in a cable termination under impulse voltage using Version 5. I used AC/DC module electric currents (ec) and electrical circuit (cir) to produce impulse voltage, and used an analytic function to define the relative permittivity as a function of electric stress (ec.normE). When I run it, I got the following error message.
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.ec.normE@VDN$t@VDN${conj@8}
- Defined as: ((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))
- Variable: comp1.ec.epsilonrrr@VDN$t@VDN${conj@8}
- Defined as: (dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))
- Variable: comp1.ec.chirr@VDN$t@VDN${conj@8}
- Defined as: ((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))
- Variable: comp1.ec.Pr@VDN$t@VDN${conj@8}
- Defined as: (comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))))))
- Variable: comp1.ec.Dr@VDN$t@VDN${conj@8}
- Defined as: ((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))))))
- Variable: comp1.ec.Jdr@VDN${conj@8}
- Defined as: (((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))))))))
- Variable: comp1.ec.Jr@VDN${conj@8}
- Defined as: ((((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))))))))
- Expression: d(d((2*(comp1.ec.Jr*test(comp1.Vr)+comp1.ec.Jz*test(comp1.Vz))*comp1.ec.d*pi*r)*(dvol),{test@4}),{conj@8})
- Feature: Time-Dependent Solver 1 (sol1/t1)
Can anybody help me on the reason and solution? Thanks a lot.
PS: I run the same model with Electrostatics (es), that is DC, without any problem.
- Function: ^
3 Replies Last Post 17 févr. 2015, 11:53 UTC−5
