Meshing thin embedded geometry
I am a relative beginner to COMSOL and I am trying to build and mesh a solid block with a shallow indent at the top. I have tried so many configurations (splitting into two layers, sweeping from different sides, etc) but each returns a different error. The problems seems to be the vertical walls of the indent.
Is there any clever way of doing it? I would be very grateful for any suggestions.
Monika
6 Replies Last Post 10 nov. 2014, 03:58 UTC−5
Posted: 10 years ago 31 oct. 2014, 07:34 UTC−4
Could you please show/submit your geometry?
Lasse
Could you please show/submit your geometry? Lasse
Posted: 10 years ago 31 oct. 2014, 07:51 UTC−4
Sure. I've tried to do it while submitting but the script seemed to be temporarily not working.
In the end I would like to have a metal thin structure (blue) embedded in a larger substrate (grey).
Monika.
Sure. I've tried to do it while submitting but the script seemed to be temporarily not working. In the end I would like to have a metal thin structure (blue) embedded in a larger substrate (grey). Thanks, Monika.
Posted: 10 years ago 31 oct. 2014, 08:04 UTC−4
Measures of the geometry?
Posted: 10 years ago 31 oct. 2014, 08:22 UTC−4
Total dimensions (width x depth x height) 2mm x 8mm x 1mm
dimensions of the thin embedded structure: 40um x 4mm x 50nm
Total dimensions (width x depth x height) 2mm x 8mm x 1mm dimensions of the thin embedded structure: 40um x 4mm x 50nm
Posted: 10 years ago 31 oct. 2014, 09:35 UTC−4
Did I understand it correct at all?
Attached my geometry with a mesh.
Did I understand it correct at all? Attached my geometry with a mesh.
Posted: 10 years ago 10 nov. 2014, 03:58 UTC−5
Yes! Thank you!
Yes! Thank you!
