Selection of surfaces on interior geometry
Hello, I am working on a project involving the simulation of airflow through a room. When I import a sealed room, I am unable to select the desired inlet and outlet within the room. When I do not place a physical roof on the room, I can select my inlet and outlet, but get a fatal mesh error. If anyone can help, please let me know.
1 Reply Last Post 21 oct. 2014, 14:24 UTC−4
Posted: 10 years ago 21 oct. 2014, 14:24 UTC−4
Hello Jeremy,
The default method to select interior boundaries changed in version 4.4 compared to earlier versions. The new default is discussed here along with how to return to the "old" method if you prefer it: www.comsol.com/support/knowledgebase/1168/
Hello Jeremy, The default method to select interior boundaries changed in version 4.4 compared to earlier versions. The new default is discussed here along with how to return to the "old" method if you prefer it: http://www.comsol.com/support/knowledgebase/1168/ Best, Jeff
