Acoustic resonance in a closed tube
Dear All,
I am trying to simulate acoustic resonance in a closed end tube.
I have attached my model, the incident sound pressure should be 3pa, and the resonance frequency should be around 198 hz.
How should I model the boundary conditions?
Thank you,
2 Replies Last Post 13 mai 2015, 13:42 UTC−4
Hello Edvin Golestanyan
Posted: 10 years ago 13 mai 2015, 00:58 UTC−4
your model maybe have some error when I open it
there is just a tube and a cylinder filled in it.
And you did not assign the material Parameters about the filler in the tube
I think you can give more information that may have more help
your model maybe have some error when I open it there is just a tube and a cylinder filled in it. And you did not assign the material Parameters about the filler in the tube I think you can give more information that may have more help
Posted: 10 years ago 13 mai 2015, 13:42 UTC−4
Also, your geometry steps are unnecessarily complicated: you subtract cylinder1 and then you add it right back, what's the point? Just draw the two cylinders and you're done. You can read on geometry creation in the Reference Guide, Chapter 7.
Also, your geometry steps are unnecessarily complicated: you subtract cylinder1 and then you add it right back, what's the point? Just draw the two cylinders and you're done. You can read on geometry creation in the Reference Guide, Chapter 7. Jeff
