Automated remeshing fails
Posted 4 oct. 2014, 18:59 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Mesh, Studies & Solvers Version 4.4 0 Replies
In the process, a few inverted mesh elements are created. To avoid this problem, I tried to use autometed remeshimg when the minimal element volume is negetive. However, the calculation fails quickly after remeshing giving the folowing error messege:
The following feature has encountered a problem:
Repeated error test failures. May have reached a singularity.
This is the same error I get if I try to solve my model without the 'exclude algebraic' option on.
Thank you,
Miri
Hello Miri
