Parametric Sweep versus Parameter
Posted 8 sept. 2014, 11:07 UTC−4 Studies & Solvers Version 4.4 0 Replies
I can use "Parametric Sweep" but I worry that this will cause Comsol to recalculate and/or store the
same solution multiple times. [ed: my testing indicates that Comsol _does_ store multiple copies of the solution even though the model isn't a function of a parametric sweep parameter]
Also, it would be good to make this sort of "not-parametric" sweep without needing to recalculate the solution.
Is there an alternative to parametric sweep for this situation?
Hello Chris Nadovich
