Combining geometry (Union) and its new position
Hi everyone,
I combined several shapes into one by using the Boolean (Union).
Now I want to perform a parameter sweep by changing the position of this new shape. Is it possible to assign a single position to the whole shape (and sweep that single parameter), instead of trying to control all the spatial relations between all its components?
Bartu
2 Replies Last Post 8 sept. 2014, 10:16 UTC−4
Posted: 10 years ago 4 sept. 2014, 06:34 UTC−4
Hi Bartu,
You can define the position of the first shape using variables (let's say X1=0 and Y1=0) and then define the position of other shapes relatively to the position of the first one (Xi=X1+dX, Yi=Y1+dY). Make the parameter sweep on the variables defining the first shape.
Dima.
Dima Apter
www.a2z-consulting.com
Hi Bartu, You can define the position of the first shape using variables (let's say X1=0 and Y1=0) and then define the position of other shapes relatively to the position of the first one (Xi=X1+dX, Yi=Y1+dY). Make the parameter sweep on the variables defining the first shape. Regards, Dima. -- Dima Apter www.a2z-consulting.com
Posted: 10 years ago 8 sept. 2014, 10:16 UTC−4
Alternatively, you could add a (Transforms->)Move node to your geometry, use the unity as the input, and move the whole unity around using the parameters of the Move node.
