Moving Mesh
Posted 11 août 2014, 02:44 UTC−4 0 Replies
I have a simple rectangular geometry with a moving heat source applied on its top. I have also defined a parametric curve on the rectangle, so that it helps me to have finer mesh around it. Since the heat source moves toward x-direction, I would like to be able to move the parametric curve with the heat source. However, I can't define it as moving object. Any idea how to move it with my heat source which has velocity of 0.1m/s? Or any idea how to create a moving mesh with velocity V toward x-direction in a solid rectangle? I appreciate any kinda help.
Thanks a lot.
Hello Mohsen Torabi
