Air Domain and a vacuum
I'm new to Comsol and trying to fix errors in my model of two quadrupoles focusing a stream of particles down a beam line. Looking at the example models I see the ones having to do with magnetic fields have a domain around the model which is usually air.
I've added a cylinder around my model and defined the material as air. But I was wondering if there was a way to do this while having my beam line be a vacuum.
Erin
2 Replies Last Post 18 juin 2014, 12:06 UTC−4
Posted: 1 decade ago 18 juin 2014, 11:53 UTC−4
Erin,
in COMSOL the materials are represented by their properties in the model. I assume that in your electromagnetic application the relevant material properties for air and vacuum are exactly identical.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Erin, in COMSOL the materials are represented by their properties in the model. I assume that in your electromagnetic application the relevant material properties for air and vacuum are exactly identical. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 18 juin 2014, 12:06 UTC−4
I didn't realize that. Thank you!
