getTableData(fullprecision)
Hi all,
I'm using livelink and I've gone through the 'Livelink for Matlab users guide.'
I have a table that I created using derived values and I want to collect the numbers in the table, 'tbl1'.
Following the guide, this should result in something like:
tabl=model.result.table('tbl1').getTableData('fullprecision')
I some times misinterpret the conventions, italic Code, vs <> that they mention in the guide, but I think I'm using it correctly here. Either way, I've tried <fullprecision>, fullprecision (as a variable rather than a string).
However, Matlab is responding with:
No method 'getTableData' with matching signature found for class 'com.comsol.model.impl.TableFeatureImpl'.
I understand I can just use the .getReal command, in place of the getTableData, but I was hoping to figure it out with the getTableData command. In the future, I may not want to split up my Real and Imag numbers.
Any ideas what I'm doing wrong here?
Thanks in advance!
Sean
0 Replies Last Post 5 juin 2014, 13:23 UTC−4
Hello Sean Rodrigues
