Edgar J. Kaiser
Certified Consultant
17 mai 2014, 13:26 UTC−4
What would the iteration index be?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
7 juin 2014, 09:05 UTC−4
No body can answer me !!!!
How i can put : var = var + 125 in comsol
comsol give me : Circular variable dependency detected
Please ho can answer me and give me solution for : var = var + 125
Mr Ivar Kjelberg were are you ? give me solution !!
Edgar J. Kaiser
7 juin 2014, 10:43 UTC−4
Well, I try once more despite you didn't tell me with regard to what you want to iterate. If it is about non-linear solver steps you could try:
var = 125*niterCMP
I don't know if it works, just try it. If your iteration index is something else you can try to find it in the documentation.
var = var + 125 is not a valid equation. It reduces to 0 = 125 which is obviously wrong.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
var = 125*niterCMP
Cheers
Edgar
Edgar J. Kaiser
8 juin 2014, 12:08 UTC−4
Thank you Edgar J. Kaiser for response
The equation : var = var + 125 : The new value in the present step of "var" = the previous value in the previous step of "var" + 125 .
10 juin 2014, 02:34 UTC−4
Where 'step' means time step I suppose? It would be a bit strange in my opinion to formulate your model like that, because the rate of change of n1 with time would depend on your time step. Rather I would include something like d n1/d t = 125.
