Variable used in Solver Configuration - where to define?
To manually set the Maximum Time Step, I would like to link it to the frequency of a boundary frequency.
But I cannot use a variable defined in Global Definitions/Variables or in Component/Definitions/Variables, as both seem to be unknown for usage in the form at 'Study 1/Solver Configuration/Time Dependent Solver1/Maximum Step'
How can I make a variable known at that point?
2 Replies Last Post 20 mars 2014, 04:54 UTC−4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 19 mars 2014, 04:56 UTC−4
The value of the maximum time step must be a positive scalar value, which you can express using global parameters (along with numbers and built-in numerical constants and mathematical functions). Variables are not supported.
Magnus Ringh, COMSOL
Hi, The value of the maximum time step must be a positive scalar value, which you can express using global parameters (along with numbers and built-in numerical constants and mathematical functions). Variables are not supported. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 20 mars 2014, 04:54 UTC−4
Ah, Thany You!
I see, it has to be defined in the parameters not in the variables section.
Ah, Thany You! I see, it has to be defined in the parameters not in the variables section.
