Niklas Rom
COMSOL Employee
12 mars 2014, 08:22 UTC−4
Hi Mikhail,
this is called thermal contact. See the two downloadable examples:
www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119
www.comsol.com/model/thermal-contact-resistance-between-an-electronic-package-and-a-heat-sink-14659
kind regards,
Niklas
Hi everyone!
Let's picture three objects densely pressed to each other. First object is heated, the other one is cooled, and the third is in between. Certain temperatures cause a gap between objects because of thermomechanical expansion and different properties of materials. How to make the progam see that three objects pressed to each other are not a single object? How to make in the program a microscopic gap between objects without geometrical modeling?
Hi Mikhail,
http://www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119
http://www.comsol.com/model/thermal-contact-resistance-between-an-electronic-package-and-a-heat-sink-14659
kind regards,
Niklas
[QUOTE]
Hi everyone!
[/QUOTE]
12 mars 2014, 09:00 UTC−4
Niklas Rom, thanks a lot!
13 mars 2014, 10:04 UTC−4
Hi Mikhail,
kind regards,
Niklas
In the example (
www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119), it is written that:
HEAT TRANSFER IN SOLIDS
Pair Thermal Contact 1
1 On the Physics toolbar, click Pairs and choose Pair Thermal Contact.
2 In the Pair Thermal Contact settings window, locate the Pair Selection section.
3 In the Pairs list, select Contact Pair 1.
4 Locate the Contact Surface Properties section. From the p list, choose Contact
pressure (solid/cnt1)...
but section Pairs does not contain Pair Thermal Contact ... I have 4.3a version... Where can I find Pair Thermal Contact?
[QUOTE]
Hi Mikhail,
kind regards,
Niklas
[/QUOTE]
In the example (http://www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119), it is written that:
