"Matlab function is not found" error in MATLAB livelink
Posted 11 mars 2014, 21:52 UTC−4 Interfacing, Heat Transfer & Phase Change Version 4.4 0 Replies
extm1=model.func.create('extm1', 'MATLAB');
Density=extm1.setIndex('funcs', 'Density', 0, 0);
extm1.setIndex('funcs', 'T', 0, 1);
mat1.propertyGroup('def').set('density', {'Density(T)[kg/m^3]'});
As soon as I execute (std1.run) a “MATLAB command window” shows up and the code execution breaks due to the following error.
Matlab function is not found: Density
- Function: Density
- Feature: Time-Dependent Solver 1 (sol1/t1)
- Error: Matlab function is not found: Density
I greatly appreciate it if you help me with this problem.
Hello Iman Ghamarian
