Running old m-files in Comsol 4.2a
Posted 17 févr. 2014, 04:56 UTC−5 Interfacing Version 3.5a, Version 4.2a 1 Reply
Problem Description
I have some m-files that have been created using Comsol 3.2. The problem is that older versions of Comsol use the FEM structure. In my lab, I run the Comsol 4.2a in Windows and I have troubles converting these files. Following the guidelines of LiveLink for Matlab users, I am looking for the choice of "COMSOL with MATLAB (COMSOL 3.5a Compatibility)". However, I cannot find it. In order to run Matlab in compatibility mode with Comsol, I run "COMSOL Multiphysics 4.2a Server" and the command "mphstart".
In reality, I am studying the example: www.comsol.com/model/aquifer-characterization-through-inverse-modeling-from-pump-tests-4410 . The m-files are in www.iamg.org/CGEditor/index.htm (aren’t free). I am studying how the code works and therefore I need to run the m-files.
Questions
1) Can I convert the FEM structure of m-file from Comsol 3.2 to Comsol 4.2a using COMSOL 3.5a Compatibility?
2) If yes, how can I have access to "COMSOL with MATLAB (COMSOL 3.5a Compatibility)"?
3) Do you have any suggestion?
Thank you in advance,
George
Questions
George
1 Reply Last Post 17 févr. 2014, 11:42 UTC−5
