How do we generate report on a 3D modeled project? a kind of technical report?
Generally what are to be mentioned/written in brief technical report of the designed project?
Thanks for the help.
S
1 Reply Last Post 31 janv. 2014, 15:54 UTC−5
Posted: 1 decade ago 31 janv. 2014, 15:54 UTC−5
In the Model Builder, you will find an item called Reports under the Results section. Its use should be pretty intuitive; it's also documented in the Reference Manual.
In the Model Builder, you will find an item called Reports under the Results section. Its use should be pretty intuitive; it's also documented in the Reference Manual. Jeff
