From a NifTi Brain Model to COMSOL Bioimpedance simulation
I have got a model of the brain from MRI images,
the segmentation is done, what I need is to create a mesh that can be imported in COMSOL Multiphysics,
I already have the materials and their electrical properties ready to use in COMSOL, the problem is that I am unable of creating a mesh that can be used,
Could anybody help me to create a mesh from the nifti model,
I would also like to collaborate with somebody that is good in modelling,
Thanks a lot and best regards
/Ruben
2 Replies Last Post 29 janv. 2014, 05:27 UTC−5
Posted: 1 decade ago 28 janv. 2014, 13:14 UTC−5
Ruben,
you have to create geometrical entities from your segmentation in COMSOL in order to assign material properties and generate a mesh.
You could check if one of the LiveLink modules is compatible with your format or whether you can use some intermediate software to convert into a compatible format.
This may also be a topic for the COMSOL support.
I don't have any experience with the nifti format, but it sounds interesting to get the link from MRI data to COMSOL.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Ruben, you have to create geometrical entities from your segmentation in COMSOL in order to assign material properties and generate a mesh. You could check if one of the LiveLink modules is compatible with your format or whether you can use some intermediate software to convert into a compatible format. This may also be a topic for the COMSOL support. I don't have any experience with the nifti format, but it sounds interesting to get the link from MRI data to COMSOL. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 29 janv. 2014, 05:27 UTC−5
Thanks a lot Edgar,
I think ScanFe can be the solution
Best regards
/Ruben
Thanks a lot Edgar, I think ScanFe can be the solution Best regards /Ruben
