How to set classpath from GUI
I have created a library of java code to make complex tasks, and I would like to use other libraries from within this code, which are only available in .jar format. When I run my .class file from within the GUI of comsol, it seems to set the classpath to the directory of the file I am running. How can I set the classpath to also include the .jar files?
Thank you
Daniel
3 Replies Last Post 13 mars 2014, 11:26 UTC−4
Sven Friedel COMSOL Employee
Posted: 1 decade ago 13 janv. 2014, 04:28 UTC−5
Hi Daniel,
if the community does not reply to that case, feel free to contact us in support.
Cheers,
Sven
Hi Daniel, if the community does not reply to that case, feel free to contact us in support. Cheers, Sven
Posted: 1 decade ago 13 mars 2014, 09:59 UTC−4
Hi Daniel,
did you find or get a solution to this problem?
Regards
Jens
Hi Daniel, did you find or get a solution to this problem? Regards Jens
Posted: 1 decade ago 13 mars 2014, 11:26 UTC−4
No. I have put this problem aside for the moment.
Hello, No. I have put this problem aside for the moment.
