Error in Two Phase Flow
I am using the Level Set Method in Comsol. When I am using the Time dependent solvers I get the following error-
The same problem using Stationary Solver I am getting the following error-\
Wrong number of dofs in initial value.
Can anyone please tell the error in the model
1 Reply Last Post 18 avr. 2016, 17:30 UTC−4
Hello Abhiroop Bhadra
Posted: 8 years ago 18 avr. 2016, 17:30 UTC−4
Hi Abhiroop,
I am using the exact same module too and am having the same problems.....May I know if you ever get around this? Thank you very much in advance!
Hi Abhiroop, I am using the exact same module too and am having the same problems.....May I know if you ever get around this? Thank you very much in advance!
