Waveguide Modeling
I am trying to make a simple model where a light source is incident of an input port of a waveguide and then it passes through a different media. I need to see the output power (Intensity) at port 2. I looked at the examples in Comsol but not able to figure out how to implement this. I am giving a simple drawing of what I need to do.
Looking forward for your help.
Thanks in advance
Manoj
1 Reply Last Post 25 oct. 2016, 01:48 UTC−4
Hello Manoj
Posted: 8 years ago 25 oct. 2016, 01:48 UTC−4
I am doing simulation for optical waveguide in which i used three ports , one as input and other two as outputs . In the port setting I choose 1[mW] as input power . Now I need to see how much output power I am getting at both output ports but couldn't be able to do so.
So is it possible to extract the received power at output ports.
Thanks in advance.
Hi I am doing simulation for optical waveguide in which i used three ports , one as input and other two as outputs . In the port setting I choose 1[mW] as input power . Now I need to see how much output power I am getting at both output ports but couldn't be able to do so. So is it possible to extract the received power at output ports. Thanks in advance.
