Problem
PROBLEM NO> 4
HOW TO APPROACH ? Solution ?
A roll of plate of thickness d is continuously moved at a velocity U through a section of length K, which heats it up with a heat flux q0. Before the plates enters the heating section, it is at a
temperature T0; and after it passes the heating section it passes through an insulated section with
no loss of heat.
Full problem in the attachment provided !
0 Replies Last Post 27 oct. 2013, 06:49 UTC−4
Hello Harshit Patel
