Crosstalk between two transmission lines
I am trying to model the crosstalk between two transmission lines (two pairs of conductor wires). What module is more appropriate to this? At a first, I think that frequency domain (RF module) would require high computational effort for such modeling. Is it possible to model crosstalk using transmission line module?
Anderson
4 Replies Last Post 23 oct. 2013, 09:54 UTC−4
Posted: 1 decade ago 22 oct. 2013, 06:07 UTC−4
Anderson,
I haven't heard about a specific 'Transmission Line' module. The RF module is the appropriate module and it should be possible to model crosstalk with it.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Anderson, I haven't heard about a specific 'Transmission Line' module. The RF module is the appropriate module and it should be possible to model crosstalk with it. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 22 oct. 2013, 13:41 UTC−4
Hi Edgar,
There is a transmission line interface in RF module in the latest version of COMSOL (v 4.3b). The main issue in using RF module frequency domain is the high computational cost required to model the crosstalk between two transmission lines, since computation of such phenomenon requires depicting the longitudinal dimension of the lines.
Anderson O. Silva
Hi Edgar, There is a transmission line interface in RF module in the latest version of COMSOL (v 4.3b). The main issue in using RF module frequency domain is the high computational cost required to model the crosstalk between two transmission lines, since computation of such phenomenon requires depicting the longitudinal dimension of the lines. Regards, Anderson O. Silva
Posted: 1 decade ago 22 oct. 2013, 14:44 UTC−4
Hi Anderson,
yes you are right, I haven't used this specific mode so far. I briefly checked the documentation and I think it is not suited to model crosstalk between two transmission lines.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Anderson, yes you are right, I haven't used this specific mode so far. I briefly checked the documentation and I think it is not suited to model crosstalk between two transmission lines. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 23 oct. 2013, 09:54 UTC−4
Since poblems of crosstalk involve lengths of propagation greater than the wavelength, I think wave optics module is more suitable to deal with. However, I don't know if this module can be straightforwardly applied to the spectral region around 100 MHz. Is there some issue related to this?
Anderson O. silva
Since poblems of crosstalk involve lengths of propagation greater than the wavelength, I think wave optics module is more suitable to deal with. However, I don't know if this module can be straightforwardly applied to the spectral region around 100 MHz. Is there some issue related to this? Regards, Anderson O. silva
