Heat transfer - defining function to calcutate stress by using calculated temperatures from COMSOL
Hi everybody,
I'm new to COMSOL Multiphysics. At the moment I am simulating a heat flux passing through a cylindrical sample using the 2D axis symmetrical function. COMSOL gave me back the temperature of the sample at "every point" and at every defined time (t=0 until t=500s) of my sample. I have a 2D revolution of my sample.
But now, is it somehow possible to define a custom physical function to calcutate the thermal stress by using the temperature from COMSOL? Is it then also possible to make a 2D revolution plot but not with temperature but then with the stress as a variable?
I tried to define a analytic function (right click on global definitions ) but i somehow can't connect it to the results from COMSOL. I then defined my parameter E (youngs modulus), a (thermal expansion coefficient) and T_0 (ambient temperature).
Does anyone have experience with such problems?
Best
Ruiyi
2 Replies Last Post 28 janv. 2014, 04:43 UTC−5
Zoran Vidakovic, COMSOL COMSOL Employee
Posted: 1 decade ago 31 oct. 2013, 08:04 UTC−4
Dear Ruiyi,
Welcome as new user to the COMSOL forum!
What you describe is possible to solve with COMSOL. There are two main approaches:
1) Solve heat transfer and structural mechanics (thermal expansion) with the individual physics interfaces (either sequentially or simultaneously)
2) Use a precoupled physics interface (e.g. Thermal Stress)
You can find many tutorials in the Model Library (View > Model Library) or on our webpage: www.ch.comsol.com/models
Also, I recommend you to work with the latest COMSOL version (currently 4.3b) if you have access to.
I hope this helps to kick-start your simulation project!
Zoran
Dear Ruiyi, Welcome as new user to the COMSOL forum! What you describe is possible to solve with COMSOL. There are two main approaches: 1) Solve heat transfer and structural mechanics (thermal expansion) with the individual physics interfaces (either sequentially or simultaneously) 2) Use a precoupled physics interface (e.g. Thermal Stress) You can find many tutorials in the Model Library (View > Model Library) or on our webpage: http://www.ch.comsol.com/models Also, I recommend you to work with the latest COMSOL version (currently 4.3b) if you have access to. I hope this helps to kick-start your simulation project! Best regards, Zoran
Posted: 1 decade ago 28 janv. 2014, 04:43 UTC−5
Hi Ruiyi,
I am modeling heat transfer induced in body tissue due to electric current and I would like to know if you found any answers for your own question in how to relate the function to the results of modeling. I mean how to define a function that shows how temperature has changed.
I would appreciate your help.
Hi Ruiyi, I am modeling heat transfer induced in body tissue due to electric current and I would like to know if you found any answers for your own question in how to relate the function to the results of modeling. I mean how to define a function that shows how temperature has changed. I would appreciate your help.
