Unit conversion
Hi all,
I wanted to convert microliter/minute to m/s
i used
1 m3/s = 3.6e12 microliter/hour formula.
But it seems to make my flow very slow.
Please suggest if I need to use a different conversion formula.
2 Replies Last Post 7 oct. 2013, 04:13 UTC−4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 7 oct. 2013, 04:08 UTC−4
This conversion is correct. If you define the volumetric flow rate using the unit syntax in COMSOL as
3.6e12[µl/h]
(for microliters per hour) then COMSOL converts it to 1 m^3/s for a model using SI units. If that is fast or slow depends on other model parameters, I guess, but in microfluidics it seems like a very high number.
Magnus Ringh, COMSOL
Hi, This conversion is correct. If you define the volumetric flow rate using the unit syntax in COMSOL as 3.6e12[µl/h] (for microliters per hour) then COMSOL converts it to 1 m^3/s for a model using SI units. If that is fast or slow depends on other model parameters, I guess, but in microfluidics it seems like a very high number. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 7 oct. 2013, 04:13 UTC−4
Thanks for the reply.
Actually my flow rate is 10 microliter/min, which i wanted to input as meter/second.
So let me try to increase the value
Thanks again
-Lalitha
Hi, Thanks for the reply. Actually my flow rate is 10 microliter/min, which i wanted to input as meter/second. So let me try to increase the value Thanks again -Lalitha
