Magnetic Horn as Numeric Multi Turn Coil Domain
Dear All,
I am trying to setup a Magnetic Horn apparatus.
It is a coil generating a toridal field where the current is injected through a radially symmetric
surface. The geometry is shown in the attached pdf slide. The issue is that I don't manage to inject
a current flow which is perpendicular to the input surface. It seems all the insulation/input/output
surfaces are specified correctly. Figure shows the COMSOL result as well.
Thanks in advance for any help.
0 Replies Last Post 17 sept. 2013, 12:44 UTC−4
Hello Silvestro Di Luise
