change the terminal voltage at capacitor
Hi all,
I'm pretty new of Comsol. I did some model for capacitor using model that found on net. But I want to change the value of terminal voltage and see the change. or change the geometry of problem and see the change. How I do this?
I'm using Comsol 4.3b.
thank you.
1 Reply Last Post 18 sept. 2013, 01:14 UTC−4
Posted: 1 decade ago 18 sept. 2013, 01:14 UTC−4
You may set a parameter as Vdc, and set it as the voltage applied on the terminal.
Then right click Study and choose "Parametric Sweep",then add Vdc as the sweeping parameter. Set the range you are interested.
You may set a parameter as Vdc, and set it as the voltage applied on the terminal. Then right click Study and choose "Parametric Sweep",then add Vdc as the sweeping parameter. Set the range you are interested.
