Coupling 1D Pipeflow to 2D axisymmetric Porous Media
I am working on coupling 1D pipeflow to 2D axisymmetric porous media. The coupling is peformed by averaging the 2D boundary to the 1D point and integrating the 1D point to the 2D boundary. The coupling variables are pressure and velocity.
I have used this average and integration operator coupling approach with 1D pipeflow to 3D k-epsilon coupling before with success.
When the model is run, the solution oscillates continuously but never converges. Plotting results while solving shows that there is an issue at the porous media inlet. The porous media inlet condition is based on integrating the pipeflow velocity at that point to the 2D inlet. Flow is not entering and passing through the porous media section like it should, and I'm not sure why that is. My model is attached. Any suggestions on how to fix this boundary inlet condition would be appreciated.
Burns
1 Reply Last Post 18 févr. 2014, 12:05 UTC−5
Hello Burns Cunningham
Posted: 1 decade ago 18 févr. 2014, 12:05 UTC−5
I am having a similar problem where the 1D flow is not entering my 2D porous bed. Did you find a way to solve this problem?
Thank you,
Jamie
Hello, I am having a similar problem where the 1D flow is not entering my 2D porous bed. Did you find a way to solve this problem? Thank you, Jamie
