Warning: Parametric solver does not support geometry and mesh dependent parameters
Dear all,
I want to sweep a parameter, but the geometry and mesh depend on the parameter. Then I get the warning message
Parametric solver does not support geometry and mesh dependent parameters.
I found a related discussion thread, where Ivar replied
In which context did you get that error, if you have selected a Solver Continuation parametrical sweep then it is because that is NOT looping over the geoemtry and the mesh.
To perform a parametric sweep to change the geoemtry and to remesh you need to add a separate "parametric Sweep" node before your solver node
Does anyone know how to add the separate "parametric sweep" node?
Thanks!
1 Reply Last Post 18 juin 2015, 22:50 UTC−4
Hello Pu Zhang
Posted: 9 years ago 18 juin 2015, 22:50 UTC−4
Right click "Study" node, select "parametric sweep"
Also see
www.comsol.com/community/forums/general/thread/36089/#p189383
Right click "Study" node, select "parametric sweep" Also see http://www.comsol.com/community/forums/general/thread/36089/#p189383
