Applying Analytical Function as Boundary Condition
I know this has been asked a lot... but none of the solutions mentioned in the search I did in the forum solved my problem. I'm simulating a piezoelectric membrane, and doing a Time Dependent Study of it's displacement.
I want to apply a time variable rectangular function as an electrical input. I already plotted the rect() function in a an1() function: Vp=45V; Rt=200us; fo=50Hz
expression: Vp*rect1(t[1/s])
argument: t
function: V
"make periodic" lower limit: -Rt
"make periodic" upper limit: -Rt+1/fo
The plot of the an1() function is exactly what I need. But when I try the apply it to the "Electrical Potential" Boundary condition (BC) I write: an1(t,V); an1(t[1/s]); an1(t,V,t[1/s]); an1(V).... all of those give the same problem: "Unexpected Unit of Input" what is the correct way to write it so the unit seen by the BC is volts [V]???
Any help will be appreciated
0 Replies Last Post 25 avr. 2013, 03:42 UTC−4
Hello David Sanchez
