Inductance of a parallel plate transmission line
I'm trying the find the lumped element parameters of a parallel plate transmission line.
I've been using the "energy method" described on pages 87 and 88 of the AC/DC Module Users Guide.
I used the electrostatics branch to apply a fixed voltage and calculate the lumped capacitance, but I can't figure out which physics under the AC/DC module to use and how to set it up so I can find the magnetic energy density.
Can anyone help direct me in setting up this model?
Thank you.
1 Reply Last Post 3 avr. 2013, 02:05 UTC−4
Posted: 1 decade ago 3 avr. 2013, 02:05 UTC−4
I believe you get that straight out of the MF physics and if you use port / Terminal lumped BC's COMSOL set's up the correct variables for you
Hi I believe you get that straight out of the MF physics and if you use port / Terminal lumped BC's COMSOL set's up the correct variables for you -- Good luck Ivar
