PML for infinite layered films
Dear folks,
I am trying to simulate a point source illuminating on a stacked films extending to infinite. A intuitive way to truncate the film, I think, is to use PML. However, when extending the layered film material into PML, the performance of PML obviously is not good, even worse than Scattering BC without PML. I attached a figure showing the field, compared to a FDTD result, reflection from the PML boundary is apparent. COMSOL technique support also indicates that PML does not work well for infinite films, and suggests to live with SBC. So I am wondering is anyone here has encountered similar problem and can share the experience. Thanks a lot.
Best Regards,
Leiming
7 Replies Last Post 20 déc. 2014, 22:20 UTC−5
Posted: 1 decade ago 21 mars 2013, 14:26 UTC−4
I do it all the time and the performance is very good. I see virtually no reflection from PML's inner boundaries within ~10^(-6) precision. Try playing with PML's options.
By the way, make sure to use same material properties for PML as for the corresponding films.
[QUOTE] However, when extending the layered film material into PML, the performance of PML obviously is not good, even worse than Scattering BC without PML. [/QUOTE] I do it all the time and the performance is very good. I see virtually no reflection from PML's inner boundaries within ~10^(-6) precision. Try playing with PML's options. By the way, make sure to use same material properties for PML as for the corresponding films.
Posted: 1 decade ago 21 mars 2013, 14:45 UTC−4
Dear Alexander,
Your comment is highly appreciated. I am very glad to learn that it is indeed possible to improve it by fine tuning the PML settings, which is also the purpose I am seeking help here.
Yes, I did use same material for the inner domain and the PML for corresponding layers. BTW, there is a metal film among the layers.
I am using Comsol v4.3a, the only parameters I saw for tuning the PML setting are PML scaling factor and scaling curvature. FEA is kind new to me, I randomly tried different values for these two, but not successful. Could you please help explain a bit more detail of, e.g. the general strategies for tuning the PML parameters,if there are. If you allow, I can send in my test model.
Thank you very much,
Leiming
Dear Alexander, Your comment is highly appreciated. I am very glad to learn that it is indeed possible to improve it by fine tuning the PML settings, which is also the purpose I am seeking help here. Yes, I did use same material for the inner domain and the PML for corresponding layers. BTW, there is a metal film among the layers. I am using Comsol v4.3a, the only parameters I saw for tuning the PML setting are PML scaling factor and scaling curvature. FEA is kind new to me, I randomly tried different values for these two, but not successful. Could you please help explain a bit more detail of, e.g. the general strategies for tuning the PML parameters,if there are. If you allow, I can send in my test model. Thank you very much, Leiming
Posted: 1 decade ago 21 mars 2013, 17:05 UTC−4
You can upload your model here
Posted: 1 decade ago 21 mars 2013, 18:07 UTC−4
Many thanks, Alex, uploaded.
Any insight you may offer is highly appreciated.
Leiming
[QUOTE] You can upload your model here [/QUOTE] Many thanks, Alex, uploaded. Any insight you may offer is highly appreciated. Leiming
Posted: 1 decade ago 21 mars 2013, 19:03 UTC−4
Sorry, can't open it because of version mismatch. I got 4.3 version
Posted: 1 decade ago 21 mars 2013, 19:28 UTC−4
No problem, that's true, COMSOL is not forward-compatible.
Anyway, thanks for discussion. See if other experts may be able to offer some help.
Leiming
No problem, that's true, COMSOL is not forward-compatible. Anyway, thanks for discussion. See if other experts may be able to offer some help. Regards, Leiming
Posted: 10 years ago 20 déc. 2014, 22:20 UTC−5
Dear Alexander Kuznetsov,
I also have the same problem, can you upload your file to show how to fine tune the PML boundary condition? thanks
Dear Alexander Kuznetsov, I also have the same problem, can you upload your file to show how to fine tune the PML boundary condition? thanks
