How to mesh finer in a specific area in 3D
My model is a insulator in 3D surroundded by air, i added a small water droplet on the insulator to observe the electric field enhancement around the water droplet.
So i need to focus on the small water droplet and need finer or extra fine mesh for the air around the water droplet, but i don t want to make the whole air have finer or extra fine mesh because this will cost me much more longer time to compute it.
My question is that is there a way to mesh the air near water droplet finer but coarser in other part of air domain.
I tried distribution but it seems just make the surface finer but not the 3D space.
2 Replies Last Post 6 mai 2013, 20:30 UTC−4
Posted: 1 decade ago 8 mars 2013, 14:39 UTC−5
you can add a small semi-sphere around the droplet. This makes a seperate domain available that can be meshed in a different way.
Cheers
Edgar
Hi, you can add a small semi-sphere around the droplet. This makes a seperate domain available that can be meshed in a different way. Cheers Edgar
Posted: 1 decade ago 6 mai 2013, 20:30 UTC−4
Hi, Edgar
Thank you so much for your idea!!
It does make sence!
Thank you!
Xin
Hi, Edgar Thank you so much for your idea!! It does make sence! Thank you! Regards, Xin
