Swirling Flow Around a Rotating Disk
Hi all, first time I've posted here!
So I've been working through the Swirling Flow Around a Rotating Disk Model:
www.uk.comsol.com/showroom/gallery/616/
It's really impressive.
I'm just wondering if it would be possible to model the swirling flow on top of the disk (looking down from above)? Does anybody have any tips about how I would go about altering the model in order to be able to view the flow directly on top the disk? I'm interested in looking at the flow patterns on the disk as the flow changes form laminar to turbulent.
Any help would be greatly appreciated.
Thanks.
1 Reply Last Post 4 mars 2013, 01:07 UTC−5
Posted: 1 decade ago 4 mars 2013, 01:07 UTC−5
I would say, if you want to remain in 2D that you would need to write out the equations yourself, using a radial force in the plane X-Y w.r.t. a cylindrical coordinate.
Else you could try in 3D to get the ful "z" height plying its influence
Hi I would say, if you want to remain in 2D that you would need to write out the equations yourself, using a radial force in the plane X-Y w.r.t. a cylindrical coordinate. Else you could try in 3D to get the ful "z" height plying its influence -- Good luck Ivar
