Determining resonant frequency
When trying to determine resonant frequencies of a piezoelectric transducer how would you go about that using the frequency domain study?
1 Reply Last Post 28 févr. 2013, 15:11 UTC−5
Posted: 1 decade ago 28 févr. 2013, 15:11 UTC−5
My suggestion is that you start with an eigenfrequency solver, to get the frequencies of the different main modes,
Thenyou run a frequency sweep, as you need to give a range for the frequency steps, and you must make these steps smaller around the resonances to catch them correctly.
I mostly use logarithmic ranges of the type 10^range(-2,1,4) or whatever fits, but then I combine several "range()" step rapidly up to -5% (below) the eigenfrequency andthen by step regularly up to +5% (above) the eigenfrequencies, then rapid steps again to next mode etc
If you have some damping its worth to plot real and imag part or amplitude and phase (and I usually plot in log scale or even log-log scale
Hi My suggestion is that you start with an eigenfrequency solver, to get the frequencies of the different main modes, Thenyou run a frequency sweep, as you need to give a range for the frequency steps, and you must make these steps smaller around the resonances to catch them correctly. I mostly use logarithmic ranges of the type 10^range(-2,1,4) or whatever fits, but then I combine several "range()" step rapidly up to -5% (below) the eigenfrequency andthen by step regularly up to +5% (above) the eigenfrequencies, then rapid steps again to next mode etc If you have some damping its worth to plot real and imag part or amplitude and phase (and I usually plot in log scale or even log-log scale -- Good luck Ivar
