dT/dt
I cannot work out how to get dT/dt ( temperature variation rate) when using COMSOL. I am a beginner and currently using a version 4. I am modelling the heat transfer of a thin pyroelectric solid and I do not know how to get a plot of dTemperature/dTime against time. I have attached a paper below which pretty much gives the results I am looking for. I just need to work out how they did it.
Faizan
3 Replies Last Post 28 févr. 2013, 01:46 UTC−5
Posted: 1 decade ago 27 févr. 2013, 02:26 UTC−5
if you solve for T (temperature (as in HT) then COMSOL makes the variable Tt readily for you Tt is DT/dt
Check carefully the doc and help for all internal variables, and/or turn on the preferences equation view
Hi if you solve for T (temperature (as in HT) then COMSOL makes the variable Tt readily for you Tt is DT/dt Check carefully the doc and help for all internal variables, and/or turn on the preferences equation view -- Good luck Ivar
Posted: 1 decade ago 27 févr. 2013, 22:19 UTC−5
Hi thanks alot for the help!
I also have a couple more problems
1. How do you change range of the x axis and y axis when your plotting a line graph for a dot within your structure. I am trying to dT/dt against seconds . But I need to reduce the time range between 1e-07 to 1e-02.
2. I have lots of colorful lines but I want just one line how do I get this. I have attached a document to show what I mean. I have also attached a paper which has the graph which i want to plot
3. The project I am using COMSOL for is a pyroelectric cell rengtangle exposed to 30 degrees. I have set the top line of the rectangle as 30 degree and the other three lines as thermal insulation. Is this correct ?? I have explained more on the document below.
Hi thanks alot for the help! I also have a couple more problems 1. How do you change range of the x axis and y axis when your plotting a line graph for a dot within your structure. I am trying to dT/dt against seconds . But I need to reduce the time range between 1e-07 to 1e-02. 2. I have lots of colorful lines but I want just one line how do I get this. I have attached a document to show what I mean. I have also attached a paper which has the graph which i want to plot 3. The project I am using COMSOL for is a pyroelectric cell rengtangle exposed to 30 degrees. I have set the top line of the rectangle as 30 degree and the other three lines as thermal insulation. Is this correct ?? I have explained more on the document below.
Posted: 1 decade ago 28 févr. 2013, 01:46 UTC−5
well I cannot tell, but when I do a simple model (4.3a below) it works OK
Hi well I cannot tell, but when I do a simple model (4.3a below) it works OK -- Good luck Ivar
