Properties of model
Hey.
How can I check the properties of the model object?
For example, the current in the coil, or the radius of the circle, the properties of the materials.
Thank you.
3 Replies Last Post 26 févr. 2013, 08:43 UTC−5
Posted: 1 decade ago 25 févr. 2013, 14:08 UTC−5
you can only post-process after having solved, or loaded the initial conditions, then you can use the Derived values node to integrate and interprete results around your domains or boundaries
Hi you can only post-process after having solved, or loaded the initial conditions, then you can use the Derived values node to integrate and interprete results around your domains or boundaries -- Good luck Ivar
Posted: 1 decade ago 26 févr. 2013, 07:08 UTC−5
Thank you for your reply.
But I had in mind early formula
geom1.feature.create c1 = ('c1', 'Circle');
You can find out where the property value before calculating.
Thank you.
Thank you for your reply. But I had in mind early formula geom1.feature.create c1 = ('c1', 'Circle'); You can find out where the property value before calculating. Thank you.
Posted: 1 decade ago 26 févr. 2013, 08:43 UTC−5
you can do measurements in the graphics view see the ruler icon, but any "calculation" is performed on the discretized geometry, hence you need a mesh and at least loading in the initial conditions into the Data sets
Hi you can do measurements in the graphics view see the ruler icon, but any "calculation" is performed on the discretized geometry, hence you need a mesh and at least loading in the initial conditions into the Data sets -- Good luck Ivar
