Error Jacobi with user-defined function
I defined a function in Global Definition to describe the graded-index. However, when I used the Solve-Modal Analysis, the COMSOL popped a window to warn error in Jacobi matrix.
Plus, I suppose my function was working well, I am not sure whether it can be a assignment in Material dialog.
If I replace my function with a constant in index value setting, the model works well.
Thank you.
1 Reply Last Post 25 févr. 2013, 13:55 UTC−5
Posted: 1 decade ago 25 févr. 2013, 13:55 UTC−5
it could well be that it should rather be defined in the Mode - Definitions rather than Global definitions, particularly if it contains references to the geometry.
Then why add it to the material ? if it's a definition of the index, OK perhaps you should define it in the material section
Hi it could well be that it should rather be defined in the Mode - Definitions rather than Global definitions, particularly if it contains references to the geometry. Then why add it to the material ? if it's a definition of the index, OK perhaps you should define it in the material section -- Good luck Ivar
