Joule Heating - Study help
Posted 6 févr. 2013, 00:37 UTC−5 Heat Transfer & Phase Change, Heat Transfer, Structural Mechanics 1 Reply
Hello all,
I am currently working on modeling the thermal stresses of a surface mounted component on a PCB. However, i am currently struggling to get the physics to work. I have followed the available online tutorials to help me out with setting the physics; however, i am getting the same error consistently:
"Failed to find a solution.
Singular matrix.
For mesh-case 0 there are 40552 void equations (empty rows in matrix) for the variable mod1.V.
at coordinates: (0.00799,0.00190047,-0.00381), (0.00799,0.00183293,-0.00381), (0.00799,0.00145389,-0.00230996), (0.00797193,0.00144694,-0.00232498), (0.00799,0.00144694,-0.00232498), ...
and similarly for the degrees of freedom (empty columns in matrix).
Returned solution is not converged."
The materials have been fully define with information found through research, and i believe i have define all the boundaries properly (i followed the instructions from the tutorials to get the physics set up).
If anyone could provide any pointers or advice as to what i am missing in the modeling, i would greatly appreciate it!
Thank you very much for your time!
Santiago
Singular matrix.
Santiago
1 Reply Last Post 6 févr. 2013, 08:18 UTC−5
