Use previous time step value for user-defined variable calculation
Hello everyone, I'm currently having some difficulties with an apparently simple task:
I have two user defined variables, A and B, one dependent on the other (circular dependency). I believe the best way to solve this is by calculating A using the value of B from the previous time step: A = prev(B,1). However, it is still flagging up a circular dependency issue. Is there any better way to do this? I am including 'previous solution' in the solver configuration.
Thanks, Javier
0 Replies Last Post 7 juin 2024, 08:01 UTC−4
Hello Javier
Reply
