How to set the conditions for simulating the vibration of ultrasonic sensors
The excitation source is set to the specified displacement, and the pressure of solid mechanics is calculated. When calculating displacement, there is displacement only when the signal is input, and the subsequent displacement is always zero. How to solve this problem
1 Reply Last Post 11 mars 2024, 08:39 UTC−4
Mark Cops COMSOL Employee
Posted: 4 months ago 11 mars 2024, 08:39 UTC−4
Updated: 4 months ago 11 mars 2024, 08:39 UTC−4
We would likely need to see the .mph file to provide specific guidance for this question. Can you upload it to the forum? Otherwise it might help to compare the model to models with similar setup like here: https://www.comsol.com/model/piezoacoustic-transducer-1477.
-Mark
We would likely need to see the .mph file to provide specific guidance for this question. Can you upload it to the forum? Otherwise it might help to compare the model to models with similar setup like here: https://www.comsol.com/model/piezoacoustic-transducer-1477. -Mark
Reply
