Time-dependent problem: noisy temperature boundary condition. Is it possible to change the noise magnitude in a sweep analysis?
Hello people,
Is it possible to sum to a triangular temperature profile, defined as a piecewise linear function in the range from zero to 6000 minutes, a random signal (describing a sort of noise) with a variable magnitude that maybe I can change in a sweep analysis? I tried everything but there is no possibility to generate a random signal in exactly the same period of the temperature profile.
What would you suggest to do?
Thanks in advance.
1 Reply Last Post 26 févr. 2024, 16:32 UTC−5
Posted: 5 months ago 26 févr. 2024, 16:32 UTC−5
Maja,
a noise signal is not periodic by its nature. In case you want to see which way a disturbance on the triangular ramp affects the model, you might try to superimpose some function that behaves less pathologic for a time dependent solver than noise. You might start with a superimposed sine wave and adjust the solver for it. Once it works you may modify the sine to make it more noise-like, e.g. by superimposing amplitude and frequency modulation to it. In any case you must choose a time stepping that resolves the superimposed function properly.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Maja, a noise signal is not periodic by its nature. In case you want to see which way a disturbance on the triangular ramp affects the model, you might try to superimpose some function that behaves less pathologic for a time dependent solver than noise. You might start with a superimposed sine wave and adjust the solver for it. Once it works you may modify the sine to make it more noise-like, e.g. by superimposing amplitude and frequency modulation to it. In any case you must choose a time stepping that resolves the superimposed function properly. Cheers Edgar
Reply
