Convergence problem in very low velocity
HI, I am using Euler euler method to simulate multiphase flow in 2D domain. When my inlet velocity is 0.001 m/s the solver is showing the below error (attached). I have used "automatic highly non-linear (Newton)" method as non-linear solver for uc,ud,and p. But whenever im using slightly higher velocity ( say 0.002 m/s) it is converging.
Is it the problem with velocity ?
3 Replies Last Post 29 févr. 2024, 00:26 UTC−5
Posted: 1 year ago 15 févr. 2024, 08:56 UTC−5
Updated: 1 year ago 15 févr. 2024, 08:56 UTC−5
Hello Lakshmi,
The file you attached seems to be blank.
Jeff Hiller
Hello Lakshmi, The file you attached seems to be blank. Jeff
Posted: 1 year ago 16 févr. 2024, 01:21 UTC−5
Updated: 1 year ago 16 févr. 2024, 01:20 UTC−5
hi, sorry, some errror occured .I am uploading the document again. Kindly check
Posted: 1 year ago 29 févr. 2024, 00:26 UTC−5
Updated: 1 year ago 29 févr. 2024, 00:26 UTC−5
Hi, iam still facing with the same issues with low velocity, Can someone help?
