Magnetic field
Posted 19 nov. 2012, 03:11 UTC−5 Low-Frequency Electromagnetics Version 4.3a 10 Replies
Does anybody know how to write this expression on comsol ( ∇/B/^2 )? I meant expression that replace "the gradient of the magnetic field norm square".
Thank you
you need to write out the full expression the derivatives are defined inside COMSOl see the doc
But I have gotten only this expression mf.Br*d(mf.Br, r), which is not the right expression I want.
if you are solving with MF your dependent variable is A the magnetic vector potential, then B is already the derivative of A, so if you want to further derive B, you should use a higher discretization (3rd or 4th order)
Thjen it's easier to express everything directly from A (check the COMSOl equations by turning on the equation view
Here is what I 'm using the expression for: I coupled magnetic field and structural mechanics, the expression is proportional to magnetic force and I'm using this expression as a body load. I used this product mf.Br*d(mf.br, r) as a body load and it works but now I want to replace it with the right expression, which is ∇/B/^2. Actually I 've tried to write it but couldn't manage to do so and every time I tried to run it, it comes up with expression error.
The equation view is already turned on.
Thank you
So is it possible to express ∇/B/^2, in a way that comsol understands...?
Thank you
you can develop the
grad(dot(B,B)) into "2*(dot(B,grad(B))+cross(B,curl(B))
(see i.e Wiki : Vector calculus identities) , knowing the variable names from the equation view, in your particular COMSOL space you have chosen, you can write this out, no ?
I guess it should be possible to write.
I was just wondering, if these two are the same. ∇/B/^2 = ∇/B^2/ ????
If so, ∇/B/^2 = 2[B×(∇×B) + (B . ∇)B] but then I couldn't be sure of B .∇ = ∇. B? I know that the divergence of the magnetic field is zero( ∇. B = 0)
Thank you very much
the two are not really the same, there is a sign issue:
If I read you corretly (but perhpas I misinterpreated it) the square of the norm of a vector is for me B*B=B^2 = a scalar representing the dot product of B with itself
but if you take the norm of this scalar, for a complex valued case you will have an sign difference, no?
from the moment you take a suqare root you have to check your signs. So the true question what is the true vector product you are looking for ?
I'm not sure but may be you right, it could be different for complex valued case.
Actually I'm looking for a force which is proportional to the negative of the gradient of the magnetic field norm square.
i.e F = -∇/B/^2, B= B(z,t)= Bz(z)*sin(wt) in the Z direction or Z-hat
And I want to use this force as a body load.
Thank you for being concerned, I really appreciate all the help.
one of the reasons I have some issues to give a cear response here is due to the complex nature of E and I do not fully understand in which environment / model you are looking at these equations.
See my comment to:
www.comsol.eu/community/forums/general/message/reply/91752/
