Jeff Hiller
COMSOL Employee
9 nov. 2012, 08:11 UTC−5
There are no tools to draw a spiral in version 3.5a. You can do it in the current version of the software, version 4.3a though.
26 févr. 2013, 12:10 UTC−5
how to draw a rectangular spiral in 3D in comsol 4.3a
27 févr. 2013, 03:30 UTC−5
in 3.5 I do not believe its possible (cannot remember for sure ;) But in 4.3 you draw a workplane, the square (or better filleted square profile (if in ACDC to avoid singularities on the edges) then add a Helix with minor radius of "0" to get the spiral shape (adjust position accordingly to start in the middle of your square profile, then you use the sweep,
What I have always problems with then is the twist angle right ;)
27 févr. 2013, 08:29 UTC−5
Thanks for reply,I will try it
27 févr. 2013, 11:54 UTC−5
There IS an option to draw a spiral in 3.5a!
However, the catch is that this needs to be done in "comsol script" or matlab environment...
I think the command in comsol script is something like "helix3d" or something...
After drawing it in script, you can import the geometry back into comsol
Sorry I can't give more details because I haven't used 3.5a in years, but I know that back when I did use it I was able to successfully draw a helical coil for analysis!
--matt
--matt
