Implimentation of equatuion
I want to implement "my own" physics into Comsol or change a physic.
How can I do that?
Thanks!
5 Replies Last Post 8 nov. 2012, 11:03 UTC−5
Posted: 1 decade ago 8 nov. 2012, 09:11 UTC−5
Regarding solving your own PDEs/ODEs:
Chapter 15 in the User's Guide manual, version 4.3a, is a solid introduction to this topic. You will find tutorial examples, with step by step instructions, in the Model Library under COMSOL Multiphysics>Equation-Based Models.
Regarding solving your own PDEs/ODEs: Chapter 15 in the User's Guide manual, version 4.3a, is a solid introduction to this topic. You will find tutorial examples, with step by step instructions, in the Model Library under COMSOL Multiphysics>Equation-Based Models.
Posted: 1 decade ago 8 nov. 2012, 09:14 UTC−5
Hola,
Probably you need to implement your PDEs with PDE Interfaces.
If your physics is only different from those available application modes in several places, it's also possible for you to modify some expressions or equations in the available modes.
Cheers!
Hola, Probably you need to implement your PDEs with PDE Interfaces. If your physics is only different from those available application modes in several places, it's also possible for you to modify some expressions or equations in the available modes. Cheers!
Posted: 1 decade ago 8 nov. 2012, 09:27 UTC−5
Check the model builder option (specially if you are in 4.3a), else use the PDE "physics/math" nodes
Hi Check the model builder option (specially if you are in 4.3a), else use the PDE "physics/math" nodes -- Good luck Ivar
Posted: 1 decade ago 8 nov. 2012, 10:10 UTC−5
Can I find the user's guide for Version 4.3 online?
Posted: 1 decade ago 8 nov. 2012, 11:03 UTC−5
The documentation is copyrighted and therefore cannot be made available online.
You can find it inside the software under the Help menu.
The documentation is copyrighted and therefore cannot be made available online. You can find it inside the software under the Help menu.
