How to solve 1D ODE using the PDE interface in COMSOL?
Suppose I have a differential equation, du/dx=x, which i need to solve using the "Coefficient Form PDE" in COMSOL. I want to solve the differential equation in an interval from x=0 to x=1. The boundary condition is that u(x=0)=0. However, in COMSOL, it seems that I need to supply boundary conditions at two points, x=0 and x=1. But, doing so would over-determine my equation. Is there any way to give only one boundary condition? P.S. I know using the ODE interface might solve the problem , however, I need to solve using the PDE interface if possible. Thank you
4 Replies Last Post 2 août 2023, 00:58 UTC−4
Posted: 1 year ago 30 juil. 2023, 15:07 UTC−4
I've attached an example .mph file that shows one way (among other possibilities) to solve your problem. It's also rather nice to see it yields the correct answer. :)
Posted: 1 year ago 30 juil. 2023, 22:21 UTC−4
Updated: 1 year ago 30 juil. 2023, 22:22 UTC−4
Thank you Robert. This works excellently. I guess the mistake I was making was that I was trying to define the derivative by substituting α=-1, instead of β=1.
However, I do have a couple of questions which I would appreciate, if you could find the time to answer.
  1. Why does substituting α=-1 (instead of β=1) in the coefficient form PDE not work? If u is a regular valued function, div(u)=du/dx in 1D right?
  2. Why does putting a zero flux condition at x=1 not cause an error, or produce incorrect results.
Thanks in advance, AR
Thank you Robert. This works excellently. I guess the mistake I was making was that I was trying to define the derivative by substituting α=-1, instead of β=1. However, I do have a couple of questions which I would appreciate, if you could find the time to answer. 1. Why does substituting α=-1 (instead of β=1) in the coefficient form PDE not work? If u is a regular valued function, div(u)=du/dx in 1D right? 2. Why does putting a zero flux condition at x=1 not cause an error, or produce incorrect results. Thanks in advance, AR
Posted: 1 year ago 1 août 2023, 22:33 UTC−4
Let's talk about your seond item first: The (default) zero flux condition (if you look at the equation for it) involves a relationship among linear operations on c, alpha, and gamma. But all of those coefficients are zero, in the example that I posted, so in that case, the "zero flux" condition doesn't impose any constraint.
Now, regarding your first item, if I were to instead set alpha = -1, then I could no longer ignore that default flux boundary condition (per the comment above). There is probably a way to make that still work (since a variety of other boundary conditions are available), but in my approach, that issue simply never arises. I chose what seemed to me to be the simplest approach.
Let's talk about your seond item first: The (default) zero flux condition (if you look at the equation for it) involves a relationship among linear operations on c, alpha, and gamma. But *all* of those coefficients are zero, in the example that I posted, so in that case, the "zero flux" condition doesn't impose any constraint. Now, regarding your first item, if I were to instead set alpha = -1, then I could no longer ignore that default flux boundary condition (per the comment above). There is probably a way to make that still work (since a variety of other boundary conditions are available), but in my approach, that issue simply never arises. I chose what seemed to me to be the simplest approach.
Posted: 1 year ago 2 août 2023, 00:58 UTC−4
Thanks Robert. Addresses my queries.
Regards, AR
Thanks Robert. Addresses my queries. Regards, AR
