Mesh error
Greetings,
I am farly new to comsol and i am trying to do a spiral coil.
I used workplane and I did the square spiral graph with polygon and to make the cross section circular I introduced another plane and draw circle after that I did sweep. When I try to do meshing with a cross section less than 3.5 cm i got error Face Is (Or Has A Narrow Region That Is) Much Smaller Than The Specified Minimum Element Size.
I tried to make mesh finner and no luck.
1 Reply Last Post 25 mai 2023, 12:47 UTC−4
Dave Greve Certified Consultant
Posted: 1 year ago 25 mai 2023, 12:47 UTC−4
I believe that the message you quote is a warning rather than an error- that is, the model will solve although the results may be less accurate.
In any case- you probably should use more advanced meshing options. You can try some of the Comsol tutorials, for example
https://www.comsol.com/learning-center/building-the-mesh-for-a-model-geometry-in-comsol-multiphysics
OR you can post your model here.
I believe that the message you quote is a warning rather than an error- that is, the model will solve although the results may be less accurate. In any case- you probably should use more advanced meshing options. You can try some of the Comsol tutorials, for example https://www.comsol.com/learning-center/building-the-mesh-for-a-model-geometry-in-comsol-multiphysics OR you can post your model here.
