Where should I put constraint
Hi All,
I'm not sure where I should put constraint or maybe I should use prescribed displacement in my model?
My model (in attachment):
I calculate the stationary state then I use stationary calculations as initial conditions for time depending study and I changed heat transfer coefficient because I assumed that steel surface starts to be cooled by water. But my thermal stresses looks falsely.
Should I use first principal stress or von Mises stress in presentation of results?
Why I get a negative value of stress?
Thank you for any insight,
Robert
1 Reply Last Post 19 oct. 2012, 09:21 UTC−4
Posted: 1 decade ago 19 oct. 2012, 09:21 UTC−4
I suppose the effect comes from the Roller condition in the middle of the model, I would haver expected that condition on Boundary "5"
then use rather a time stepping of the type: as heat diffusion has a nice decay
2^{range(-1,0.5,10)}
then your slot is not really physical, as with these temperature the two bricks will exchange heat, but that is probably OK as a first approach
As I cannot really understand what is fixed and what is rigid here it's difficult to suggest something
Hi I suppose the effect comes from the Roller condition in the middle of the model, I would haver expected that condition on Boundary "5" then use rather a time stepping of the type: as heat diffusion has a nice decay 2^{range(-1,0.5,10)} then your slot is not really physical, as with these temperature the two bricks will exchange heat, but that is probably OK as a first approach As I cannot really understand what is fixed and what is rigid here it's difficult to suggest something -- Good luck Ivar
