Henrik Sönnerlind
COMSOL Employee
1 year ago
2 mai 2023, 05:25 UTC−4
Since it is a nonlinear problem, it is diffcult. Ordinary frequency domain analysis is not applicable.
There are two possible approaches:
- Run a time dependent solution to steady state for each excitation frequency. This is time consuming.
- Implement a harmonic balance method. This assume quite some familiarity with the software.
Henrik Sönnerlind
COMSOL
* Run a time dependent solution to steady state for each excitation frequency. This is time consuming.
* Implement a harmonic balance method. This assume quite some familiarity with the software.
1 year ago
5 mai 2023, 14:51 UTC−4
Can you please explain little bit about the implementation of harmonic balance method in comsol for the above problem?
Henrik Sönnerlind
COMSOL Employee
1 year ago
8 mai 2023, 02:57 UTC−4
I don't have an example of an implementation of the harmonic balance method, but I know it has been done in COMSOL for electrical simulations.
A short introduction to the method can be found in https://en.wikipedia.org/wiki/Harmonic_balance
I think the easiest (but maybe not very elegant) approach is to add one physics interface per harmonic, each operating at its own frequency. Then, coupling terms need to be inserted for the transfer of energy between the frequencies which is an effect of the nonlinearity.
Henrik Sönnerlind
COMSOL
