Problem with visualizing component of E field - please help
Posted 2 oct. 2012, 15:09 UTC−4 3 Replies
I have been working to create a model of two conductor plates with a hole through the center. I am interested in the uniformity of the E field between the plates and decided to use a surface plot to show the x component of the E field (Ex) on a 2d cut plane view of my geometry.
My problem is that the color legend shows that there is some E field in the conductor plates near the center hole - of course this is not possible. The problem is worsened when I decrease the range for the color legend.
I have tried meshing more finely, but nothing seems to make a difference. When I plot actual E field lines, there is clearly no E field anywhere inside the plates, so I don't think there is any problem with my model.
Can you please take a look at my screenshots and help me find the problem? I would attach my model, but it is over the allowed file size for attachments.
thank you
i49.tinypic.com/2u76s20.png
i46.tinypic.com/wwn7e8.png
thank you
3 Replies Last Post 3 oct. 2012, 12:33 UTC−4
